95 accord erratic miss on 2nd start
Old Nov 19, 2010 | 10:34 AM
loyalty4242's Avatar
Default 95 accord erratic miss on 2nd start
hello everyone, i have a 95 accord auto trans with a 2.2L v-tec. So my issue is you can drive for hours and never shut the car off and have no issues at all BUT the moment you shut the car off and restart the car you go to pull out of the driveway and about 1800rpms it studders and erratic mis fire symptoms it jumps and skips from 1800rpm up past 3000rpms. i have replaced the ECU, plugs, wires, distributor, throttle body, tps, map sensor and fuel injectors. I dont have a CEL, im at my witts end and about broke from all this any ideas or suggestions are much appreciated thank you all ahead of time
Old Nov 19, 2010 | 12:37 PM
See following from DIY.
https://www.hondaaccordforum.com/for...ead.php?t=3687
Disconnect EGR and see if that causes problem to disappear. If yes, then EGR blockage problem is confirmed. CEL will need to be reset.
LCS
Feb 11, 2009 01:27 PM
will93
Apr 4, 2008 12:03 PM
EEL
Jun 22, 2007 10:30 PM
chintonky
May 12, 2007 12:21 PM
jary
Jul 25, 2006 09:46 AM
