95 accord ex axle help (not CV)
Old Sep 28, 2010 | 10:49 AM
bcreight's Avatar
Default 95 accord ex axle help (not CV)
Hey guys, i need some help. I recently had my CV joints taken care of but since then, I now have a loud “POP” (one that you can feel in both seats as well) coming from the center of my front-end when I turn or there’s a significant weight-shift. I’m thinking it may be my axle as I know the CV stuff (clicking etc), plus this is the middle of the car and it's physical as well as audible. Bad axle? Poppoing axle? Any ideas?
Thanks! Brian
Old Sep 28, 2010 | 03:21 PM
The CV joints are the axle.
See if the CV joints are properly seated in the transmission and the knuckle. If you had a shop do the work, you should take it back to them to diagnose.
Old Sep 28, 2010 | 08:47 PM
The anti-sway bar rubber cusshion washers on ends of the A/S bar can shift and cause a popping sound when turning. Eaxmine the rubber washers and A/S bar ends for slack. If you can push/pull the bar this may be the problem. Easy fix.
Old Mar 16, 2011 | 12:09 AM
fordmechanic's Avatar
i do know there are clips that hold the axles in and its possible they arent staying clipped it
Old Mar 16, 2011 | 08:43 AM
If it's a big structural "POP" and you feel something shift, I'd look closely at suspension balljoints. Control arm's inboard mounting points might be moving? Maybe even the whole sub-frame moving?
The axles aren't controlling the position of the wheels. You're looking at suspension arms and ALL their pivots & attachment points.
kmg1
Sep 22, 2014 08:37 PM
keithly
May 1, 2011 03:28 PM
cleven
Feb 20, 2011 11:27 AM
littledrakon
Feb 6, 2009 04:46 PM
nixalot
Jan 25, 2007 02:02 PM
