Sponsored by:
Sponsored by:
95 accord ex inside door lock
Old 03-09-2017, 04:39 AM
rode2nowhere's Avatar
Default 95 accord ex inside door lock
JUst wondered the inside door lock will not lock by hand, it unlocks, works with power switch and works with key, is this normal?
Old 03-09-2017, 09:16 AM
Which door and how are you trying to lock it?
Driver's door will not lock unless the door is closed. Say you are sitting inside, close the door, then lock it manually.
If you are trying to lock it with the door open, I think it'll work if you pull the door-latch lever while locking it.
Probably designed that way to prevent locking the keys inside??
Old 03-09-2017, 05:38 PM
The Toecutter's Avatar
Yup. On my 97, if you hit the power lock button, it'll lock the doors, then unlock the drivers door. Once you're outside the car (door open) if you lift the outside door handle and manually push the door lock button, it'll go into the lock position. Close the door and it's locked. Like Jim said, I believe it's so you don't lock your keys in the car. On my 99, or my wife's 00, the door will lock, and you can lock your keys in it.
Old 03-10-2017, 04:38 PM
glad its all good, door panels can be put back on now
pmay805
03-16-2015 10:41 AM
Doublel
03-11-2013 07:57 AM
nismogrendel
02-07-2013 07:03 PM
d0nd0n
02-05-2012 08:31 AM
bczupryna
02-11-2006 05:50 AM
Quick Reply: 95 accord ex inside door lock
