95 Accord EX - PLEASE HELP!!! RPM gauge bounces all over?
Old Aug 21, 2009 | 01:54 PM
nubuck83
Default 95 Accord EX - PLEASE HELP!!! RPM gauge bounces all over?
1995 Honda Accord Ex V6 2.7L Auto
When I am driving the car the RPM gauge starts bouncing all over. I mean from 0 to 5000 rpm. The car does not bogg down or rev up with it. But it will downshift and up shift to early. Not so bad that you cannot drive it. Just sitting idle it will still bounce but idles normal. Happens at high speeds or if you drive it to hard. Does not happen every time. Any help or suggestions will be great as to what the problem might be.
Just changed Plugs, wires, distributor cap and rotor. Check engine light is not on to check any codes
Thanks
Old Aug 21, 2009 | 02:35 PM
The tachometer signal is generated from the ignition coil on the 95-97 V6 engines.
I would first check that the plug at the coil is on securely and that the terminals are clean. While you are in there, check the ignition control module.
You can test the resistance on the coil. I attach shop manual pic.
In my manual, it looks like the D terminal is the one that goes to the tachometer, but it doesn't specify a resistance. My guess is that if A-D or B-D is an open circuit, then the coil is suspect.
Attached Thumbnails 95 Accord EX - PLEASE HELP!!!  RPM gauge bounces all over?-untitled.jpg
Old Aug 21, 2009 | 03:13 PM
nubuck83
Thanks so much. I am going to check this out over the weekend and I will let you know what I find. Thanks again.
bougie_44
Feb 21, 2022 01:13 AM
esan805
Mar 29, 2012 02:33 PM
techjohnny
Feb 11, 2011 06:34 PM
Richlady
Sep 9, 2010 09:13 PM
rdhargro
Apr 15, 2009 07:06 AM
