95 Accord Headlight problem. PICTURES.
Old May 16, 2011 | 10:03 PM
4x4Accord's Avatar
Question 95 Accord Headlight problem. PICTURES.
Hey guy i am having a headlight problem on my accord.
when i plug the headlight in , it wont come on but , the the bumper signal and taillight signal turn on like a regular light , and the corner light doesn't turn on.
But when i unplug the headlight the corner signal turns on and the taillight works normal , but the bumper light turns off.
Help please??
Headlight Pluged in :
Headlight Unplugged :
Old May 17, 2011 | 12:40 AM
I had this problem on my 95.
Clean the ground that is on the bumper on the passenger side. You may have to jack up the front of the car to get easier access. It took me about 15 minutes to fix.
Download the 94 shop manual from one of the links in the online manuals thread in the DIY section. The electrical section shows the relay and ground location on your car.
Old May 17, 2011 | 12:42 AM
4x4Accord's Avatar
Ok will do tomorrow and see if it is the ground.
Old May 17, 2011 | 12:53 AM
It is a metal bracket with plastic connector with a bunch of black wires going to it.
I unbolted the bracket, used a dremel (you can use a file) to clean where the washer touched the bracket.
I cleaned as much rust off of the bolt and washer as I could.
#54 is the what the ground looks like. You can also get a new bolt from the dealership for less than $5.
Old May 17, 2011 | 01:03 AM
4x4Accord's Avatar
PAhonda : Thank you for the very helpful information i will be sure to follow your step tomorrow!
Old May 17, 2011 | 04:26 PM
4x4Accord's Avatar
Great new!
Headlight is now work!
The last owner never hooked up the ground , so now everything works thanks for the help again!
Old Dec 26, 2011 | 04:35 PM
outlaw423's Avatar
I have the very same car and I did bolt the grounds or #54 and only the passenger headlight started working. I checked the bulb fuse.... also the blinker to that side blinks faster than the other.Checked the bulbs front and back...wtf this is frustrating...help please
EXplicit02v6
Aug 29, 2012 12:14 AM
Paul79UF
DIY Answers.
Jun 16, 2011 08:42 AM
Kasstastrophy
Aug 5, 2007 09:58 PM
elmillon77
Nov 18, 2006 05:52 PM
