95 Accord LX 2.2 (Idle drops way too much when cooling fan kicks in)
Old Apr 9, 2011 | 11:36 AM
  #71
Custnam's Avatar
TX-Ok, as with everyone else-trying to find the source of what is gounding the red/blu wire when it should not be.
In post 16 you jump Thermo A on t-stat housing and only the "right" fan came on. First, is this the right/pass side fan-known as cooling fan- or was it the left/drivers side fan-known as condensor fan.
EDIT: Might see if you car has had this repair/recall done?? Again looking for any ideas, this came to me a few minutes ago:
Honda Motor Co., Ltd. has decided that a defect which relates to motor vehicle safety exists in certain 1995 - 97 Accords. The factory-installed air conditioner wire harness in certain 1995 - 97 Accords may have been improperly routed, allowing some wires to rub against each other. Eventually, the insulation covering the wires may wear through and possibly cause a short circuit. This problem is usually detected by a blown fuse, a dead battery, or a malfunction of the air conditioner. A short circuit could also cause the under-hood wiring to overheat and smoke. In the worst case, a short circuit could cause a fire in the engine compartment.
Wow, good find. I had no idea about that. Im not even sure how I would be able to find out if my car had that issue, and if it was fixed.
@TexasHonda. Ill check that out and report back what I find.
UPDATE: I tried to attach the PDF for the inpect and repair info but it was too large a file. Check this out!!.
Powered by Google Docs
Wouldnt it be so awesome if this was whats wrong. Im going to check it now.
Old Apr 9, 2011 | 11:45 AM
  #72
Register you car with Honda America, owners link I think. Or you can call the dealer and they can look it up by the VIN, just not sure if they are open today. My 95 EX has had the SRS recall done but not this ac wiring....again trying to find why there is ground on that wire when it is running and thermo A is jumped (post 21)????
Old Apr 9, 2011 | 11:54 AM
  #73
Custnam's Avatar
Did you see my link above? All I did was copy and paste the whole notice you posted in a google search and I found the service bulletin and how to fix it. Here it is again if you need it. Powered by Google Docs
Im going out to look at my car now. (fingers and toes crossed) Also to answer your question about wich fan ran when I jumpered the plug it was only the cooling fan. (passenger side)
Old Apr 9, 2011 | 11:59 AM
  #74
No missed that, looks like you updated about the same time I submitted....GOOD LUCK.
EDIT: After reading it, doesn't look like that might help???
Old Apr 9, 2011 | 12:28 PM
  #75
Custnam's Avatar
What do you get if you pull the AC compressor relay and check pin that has the red/blue wire for connection to ground. Does it show a ground all the time, keysitch on, engine running?
Texas. The red/blue is open with key off and in pos 1. Then its closed in pos 2 and car running
Old Apr 9, 2011 | 01:13 PM
  #76
Custnam's Avatar
Unfortunately im not finding anything. Is the red/blu working like its suppose to?
Old Apr 9, 2011 | 02:09 PM
  #77
crispin's Avatar
I know what I would do.
I am all about the simple solutions.
Run a toggle switch from in the car to the a/c clutch. (keeping the circuit open)
That way you can keep the switch in the off position unless you need the a/c on.
Then you only have to deal with this problem when you use the a/c.
There, depending on where you live, you now have no problems 75% of the time.
That would work for me.
Old Apr 9, 2011 | 02:11 PM
  #78
No, that is what has everyone confused?
Sounds like there is a short in the wire somewhere. When the green wire to the Cond fan relay is grounding so is the red/blu on the ac clutch relay. Hate to ask but see if there is continuity between those two.
Which fan came one when you jumped thermo a (green connector on t-stat)?
Old Apr 9, 2011 | 02:20 PM
  #79
Custnam's Avatar
When I jump it the cool fan pass side comes on. There is no contnuity between the 2 until key in number 2 position
Old Apr 9, 2011 | 02:33 PM
  #80
So, once you turn the key on, pos II, there is continuity between the green wire on cond fan relay and the red/blu wire on ac compr relay....but with the key in the same pos, and you jump thermo a, only one fan (right/pass) runs.
