95 accord lx engine "chugging" at low rpms help!
Old Jun 17, 2014 | 12:50 AM
the_tensl's Avatar
Default 95 accord lx engine "chugging" at low rpms help!
i just sent my car in to replace a blown head gasket and replace the distributor module, and i just got the car back and it starts and idles fine but once you give it a little gas (just over 1000rpms) its starts jumping like its "choking" or "chugging". its really jumpy when i accelerate but once i get about 25mph it drives ok for a little while then the rpms just drop back down to 700 and drastically slows the car down, I jumped the wires under the dash and it gave me an idle air control valve code, so i replaced it and still same problem i cant figure it out any help would be appreciated (i checked the coil, the spark plugs, air intake leaks, the mass airflow sensor)
its a 95 accord lx wagon 2.2 4cyl. auto trans.
Old Jun 17, 2014 | 07:37 AM
So you still have code 14 (IACV circuit fault)? If yes, then problem is likely not the IACV, but the connector, wiring, or ECM. Work done recently (head gasket) has lots of potential to damage wiring and cause this code.
Check wiring carefully and test wiring from ECM to IACV for continuity.
A missing ground from engine to throttle body could might also cause this problem.
Old Jun 17, 2014 | 01:48 PM
the_tensl's Avatar
yeah thats exactly what i was thinking cos it ran fine before i took it in but the distributor mod went out and someone told me since water was coming out of my exhaust pipe i had a blown head gasket so i just replaced that as well i took it too a college to get it done and i feel like they didnt connect something properly cos there was a few loose bolts here and there so im gonna go and check that thanks alot
jaffadog
Feb 6, 2015 01:16 PM
ghostpilot
May 25, 2011 12:06 PM
byrothapyro
Oct 5, 2010 04:58 PM
tris320
Jun 16, 2010 11:08 PM
HondaAccordNewb
Oct 18, 2007 06:51 AM
