95 accord must keep turning ignition key to stay running
Old Mar 23, 2007 | 03:40 PM
coronny
Default RE: 95 accord must keep turning ignition key to stay running
New info - in talking witha Honda dealer, he told me that there is a part called the steering switch which plugs into the steering column (where you put the key in), and thenthere is a wiring harness with connectors at both ends thatwould plug into the other side of this steering switch. The question is would it be this steering switch or the wiring harness - I don't want to assume what you meant when you said just replace the electrical part of the ignition switch, as both parts are order-in I would be stuck with it. I will be anxiously awaiting a reply...hope I'm not being too much of a pain!
Old Mar 23, 2007 | 05:05 PM
deserthonda's Avatar
electrical portion of ign switch 95 accord ex
part # 35130-SV4-003 it is about 40 dollars
Old Mar 23, 2007 | 05:34 PM
coronny
Once again I thank you.
Old Mar 31, 2007 | 02:38 AM
coronny
Had to order the part in ($70.00 CDN.), replaced it, and it works great -- problem solved. I even convinced my wife to lose the 5 lbs. of keys from the ring just in case!
Thanks again!!
timbone83
Jul 11, 2013 05:53 PM
Mostly Vacant
Dec 13, 2012 10:00 AM
huhdo
Aug 30, 2012 09:06 PM
p3z
Dec 12, 2006 12:39 PM
sparkyg
Jul 12, 2006 09:41 PM
