95 accord shifts late, and high RPM
Old Feb 28, 2011 | 02:55 PM
Taintd95EX's Avatar
Default 95 accord shifts late, and high RPM
i have a 95 accord ex 4 cylinder. Lately it has been shifting really late after it reaches really high RPM. After lengthy drives it gets even worst. takes for ever to shift and even higher rpm. any ideas?
Old Feb 28, 2011 | 04:55 PM
I would check for transmission and/or engine codes. See DIY section on how to get CEL codes. Usually the D4 light will start flashing for transmission problems, but not always. The check engine light will turn on for engine problems.
Post any codes you find on here.
I would adjust some of the slack in the cable from the throttle body to the transmission. I would also use some throttle body cleaner to clean out the shift and lockup solenoids.
If you are due for a transmission fluid change, I would change using Honda ATF. Don't have the transmission flushed.
yamahabalu
Sep 28, 2009 02:11 AM
willys.51
Aug 3, 2009 01:34 AM
willys.51
Jul 31, 2009 07:24 PM
jose310
Mar 15, 2008 12:07 AM
Mobile05
May 19, 2005 06:03 PM
