95 Accord V6
Old Oct 6, 2022 | 03:57 PM
azphil's Avatar
Red face 95 Accord V6
Check engine light on- OBD 1- can't pass emissions in AZ - flash code 7- Had Throttle sensor replaced and calibrated by Factory authorized Tech for $250. Light still on. Vehicle too old to put a lot more $$ into it. suggestions?
Old Oct 6, 2022 | 04:44 PM
Your V6 accord is OBD2. The OBD2 connector is behind the ashtray. The OBD2 code may be more specific and help identify the problem, so most parts stores will scan your car as a free service. You can post the actual code on here.
Any other work done on your car recently, or any other issues?
Are you thinking about doing the work yourself?
Old Oct 6, 2022 | 04:56 PM
azphil's Avatar
So there is another connector besides the one behind the glove box where you jump for the flash codes? Auto Zone and O'rielly both say its OBD 1 and can't pull codes
Thanks
Old Oct 6, 2022 | 05:16 PM
Pull out the ashtray and you should see the obd2 connector. The 95 V6 is obd2, but you can also check the obd1 way.
Old Oct 6, 2022 | 05:27 PM
azphil's Avatar
Thanks- will do and give you update
Hector215
Apr 13, 2013 02:23 PM
superfly831
Sep 27, 2012 12:07 AM
superfly831
Feb 1, 2012 01:26 PM
yeah_thao
May 29, 2008 11:44 AM
imallama
May 8, 2008 02:00 AM
