95 Accord whinning noise and will not start
Old Mar 19, 2015 | 02:05 AM
fbh11201's Avatar
Default 95 Accord whinning noise and will not start
hi folks,
My son has a 95 accord and it makes a whinning noise when he tries to start it. The engine doesn't even attempt to turn over, it only makes a whinning noise like an empty blender. Please help with what could be the prob. Thanks
Old Mar 19, 2015 | 03:00 AM
UhOh's Avatar
Originally Posted by fbh11201
hi folks,... The engine doesn't even attempt to turn over, it only makes a whinning noise like an empty blender. ...
If a car won't turn over it's usually a bad starter. NAPA.
Old Mar 19, 2015 | 11:22 AM
Check battery and connections are clean/secure, but I agree that failed starter is likely.
Old Mar 19, 2015 | 11:43 AM
A whining noise "like an empty blender" might actually describe an engine turning over without any compression. Like a broken timing belt or bent valves.
When you try to start, watch to see whether the external drive belts (alternator etc) are spinning.
If you're lucky, it's a broken starter where the starter motor is running but the pinion gear isn't engaging the flywheel. In that case, the external belts will not be spinning.
Old Mar 20, 2015 | 06:23 AM
Turtlehead's Avatar
Agreed Jim. Recommend checking the crank pulley while cranking it to see if it turns. If turns then bad belt etc., if does not turn then likely starter not engaging.
Tony1M
Nov 6, 2023 08:29 PM
rlmedina321
Nov 12, 2013 04:28 PM
gasface11
Jul 11, 2012 12:33 PM
crazymikeyo5
May 5, 2008 09:23 AM
