95 engine replacement?
Old Jun 13, 2015 | 03:13 PM
You will want the vtec engine, because the ECU throw an engine code without it. It may run poorly.
You would want a 94 or 95 EX engine. They are identical to your current engine and will be a "easy" swap. The less complications, the better.
A 96/97 EX engine will work too, but you need your current 94 distributor.
Check out car-part.com for used engines. You can search by price or distance. Craigslist is another source you may want to search.
Old Jun 17, 2015 | 10:22 AM
elricofimryr's Avatar
Okay, question #2. Based on the idea that I found and installed another v-tech engine, is the radiator the same style across all the years? Also, can I look for a non-vtech car's radiator, as long as it's within a couple of years? The top of my radiator's developed a bit of a problem, looking to replace it too.
Old Jun 17, 2015 | 10:31 AM
I haven't actually gotten the new(ish) engine yet, but assuming that I will get it, just trying to figure out how wide of a range of radiators I can look for. If it has to be that year and model, I'll have to narrow the search parameters quite a bit.
Old Jun 17, 2015 | 11:16 PM
You can try car-part.com for a radiator for your specific accord and see what years are returned as matches. I'd assume the 94-97 accords will work.
You can pick up a new one for ~$100. I think I installed a denso brand radiator in my old 95 accord.
s4m222
Dec 22, 2009 12:31 PM
markwolfe07
Nov 15, 2008 08:11 PM
taengok
Aug 30, 2008 11:18 PM
Thwh
Apr 10, 2005 09:28 PM
