95 Honda Accord battery drained
Old Oct 28, 2014 | 01:54 PM
Panchin's Avatar
Default 95 Honda Accord battery drained
Hi, need some help. I've put in 3 new batteries and change the alternator 3 times and my battery keeps draining within 3 days. I put a new alternator and battery and while the car is on I remove the positive cable on the battery and the car turns off. Any suggestions would be greatly appreciated.
Old Oct 28, 2014 | 09:32 PM
What is the voltage on the battery when the car is off? What is the voltage on the battery when the engine is running?
Old Oct 29, 2014 | 12:34 PM
Panchin's Avatar
The battery is currently drained. I have to re-charge it. What reading should I have while on and off?
Old Oct 29, 2014 | 05:18 PM
A good battery will have 12.6V when the car is not running. When the car is running, the battery should have around 14V.
Old Oct 29, 2014 | 06:21 PM
Your car should have a signal wire to the alternator (maybe labeled "C"??)
It's supposed to work like this:
If the battery voltage is good, and the ELD is not measuring "much" electric load, then the ECU will connect that signal wire to ground, which tells the alternator to shut off.
However...
If that wire is worn through & shorting to ground, THAT will make the alternator shut off without the ECU "giving that command". Same thing will keep happening with new alternators.
So check your wiring harness to the alternator. Pinched a wire under a bracket somewhere? Rodents chew through the insulation?
Old Oct 29, 2014 | 08:09 PM
1. Honda's utilizes a dual mode charging system to increase fuel efficiency and reduce drag on the engine on start-up. The ECM/PCM determines charging based on info. from the ELD. During heavy load, the ECM/PCM can set charging voltage for high output (~14V - 15V). During light load and start-up, the ECM/PCM sets charging voltage for low output (~12 - 13V).
Most previous generation Hondas had alternator/voltage regulators which utilize five terminal wires: Ignition (IG), Control (C), Field Reference (FR), Battery (B), and Lamp (L). The wires between the alternator's voltage regulator and PCM are the C, FR, and L wires. The ECM/PCM can control charge modes (high or low output).
The ECM/PCM will not shut off the alternator.
2. The issue may be due to excessive parasitic draw. This video shows how to narrow down the problem area.
Old Oct 29, 2014 | 08:22 PM
For info. only: If under-dash Fuse No. 4 (7.5a) was blown or there was an issue with IG wire (Blk/Yel wire), then the alternator won't charge. Fuse No. 4 and the IG wire supplies the ignition input that turns on the alternator/regulator assembly.
Old Oct 30, 2014 | 11:04 AM
Panchin's Avatar
Thank you all so much! I'll follow these steps!
CurryBomb
Jun 18, 2013 09:57 PM
SeanAccord
May 18, 2010 08:24 PM
kdozier
Dec 27, 2009 08:03 PM
smoletx
Feb 20, 2008 10:13 AM
maro
Mar 26, 2007 08:39 PM
