Urgent! Battery being drained!
Old Dec 24, 2009 | 03:20 PM
kdozier's Avatar
Default Urgent! Battery being drained!
Hi all. Where is the switch at that cuts off the "door/seatbelt" light when you open and close the door??? This is urgent! The "L" shaped switch inside the door jamb isn't cutting the light off. Is there another switch inside/near the door that cuts the light off??
Old Dec 24, 2009 | 05:05 PM
kris_loehr's Avatar
You don’t say which Accord you have. The dome light won’t go out if the switch at the dome light is in the wrong position. I believe it is the center one. Or are you talking about the door position (open or closed) on the dash
Old Dec 24, 2009 | 06:24 PM
kdozier's Avatar
Sorry. I should have been more specific. The red light on the instrument panel that reads "door/(seat belt icon)" will not turn off.
Car model is in the sig
Old Dec 25, 2009 | 07:17 PM
91excoupe's Avatar
you might try pulling your interior light fuse for a temporary fix.
Old Dec 27, 2009 | 08:03 PM
kdozier's Avatar
Default Update: Seat belt light
I'm certain that the seat belt switch is my problem but have no time to mess with it right now. Disconnecting the battery isn't a big problem but I can't do it every time the car is shut off. I'm hoping this will work.
Panchin
Oct 30, 2014 11:04 AM
CurryBomb
Jun 18, 2013 09:57 PM
SeanAccord
May 18, 2010 08:24 PM
smoletx
Feb 20, 2008 10:13 AM
maro
Mar 26, 2007 08:39 PM
