95 honda hard start
Old Jun 25, 2016 | 09:14 AM
jazzman1965's Avatar
Unhappy 95 honda hard start
95 honda accord hard start hard or cold you have tou play with gas pedal or use starting fluid to start it can someone help find problem
Old Jun 26, 2016 | 03:29 AM
Welcome to HAF
A few questions for you.....is the CEL on when the car is running? Are the tune up items (cap, rotor, plugs, inspect wires) up to date?
Old Jun 26, 2016 | 07:47 PM
i gave it a tune up..... plugs cap rotor and wires and replaced the main relay ...and idle speed sensor....but you have to flutter the gas pedal for it to start or spray starting fluid and fluter or play with gas pedal
Old Jun 27, 2016 | 08:11 AM
See whether fuel is holding its pressure:
- Turn the key to ON but don't immediately turn it to START.
- After 1 or 2 seconds turn the key to START.
If this makes it start reliably, then your fuel system is leaking back into the tank. (If it were leaking OUT, you'd probably smell fuel.)
The fuel pump has a check valve to prevent fuel flowing back into the tank when it's shut off. Maybe that's leaking a bit.
The FPR should close up and not allow the pressure to bleed off through the return line.
This doesn't exactly match your symptoms, but it's easy/free to check & rule out as the problem.
ps: I'm gonna move this to General Tech, because it's more likely to get noticed over there.
mlandon
Nov 22, 2013 11:43 AM
Lunalobowolf
Oct 26, 2012 09:33 PM
brotherbrown
Oct 11, 2012 12:01 PM
bpethomas
Jun 5, 2012 10:47 AM
joshualittlefield
May 19, 2011 08:22 AM
