95 LX Auto - hard shifts
Old Jan 15, 2008 | 11:07 PM
  #21
Gopal's Avatar
Default RE: 95 LX Auto - hard shifts - Update 2
Update 2
Two days and 30 miles later the shift is getting better all the time. I cannot believe what just one drain-fill can do to shifting. I will wait till the weekend to do another drain-fill. I do not wish to give the tranny a 'shock' by completely changing the fluid all at one time. ... or I am just plain lazy...
I'll keep updating for the next month or so on the shift conditions. I plan to do a drain-fill 4 times. 1 down 3 to go.
Old Jan 15, 2008 | 11:27 PM
  #22
nafango2's Avatar
awesome. I remember when I changed the trans fluid for the first time. The trans. never shifted so smooth before. Of course the previous owner had NEVER done a trans fluid change in the 90k miles she had the car, so it helped. a lot.
Old Jan 16, 2008 | 12:37 AM
  #23
patpatpat's Avatar
ORIGINAL: Gopal
Update 2
Dang thats a lot of Trans fluid!
Old Jan 16, 2008 | 06:36 AM
  #24
Gopal's Avatar
ORIGINAL: patpatpat
You are right. And I am beginning to think that Honda-policy of drain-fill once every 30K miles (or is it 15K?) is actually sufficient to keep the trans running. 4x drain-fill might be an avoidable waste.
But we will see.... if the 2nd drain-fill doesn't produce much difference, I'll stop....
Old Nov 9, 2013 | 02:16 AM
  #25
kobiewan's Avatar
This particular year honda accord does shift harder yes. It was done to improve transmission life and prevent slippage. my buddy has a 95 civic automatic with 370k and the original transmission. shifts hard but it will last a very long time. don't try to change it. now if it knocks things off the dash then there is a problem.
Old Nov 9, 2013 | 07:19 AM
  #26
Rilex's Avatar
while not check all the solenoids if they are working normally. My accord 98 was shifting hard and erratic from gear 1 to 2, I have to replace the clutch pressure control solenoid labeled A2. It starts shifting smoothly when driving. That's all
Old Nov 9, 2013 | 12:12 PM
  #27
kobiewan's Avatar
Riley does your accord get kind of clunky at low speeds when car is warming up? mine has always done that.
Old Nov 10, 2013 | 05:55 AM
  #28
Rilex's Avatar
when I was having problems with my transmission it was making clunking and jerking at low speeds but at high speed it shifts smoothly. i changed the clutch pressure control solenoids all gears begins to shift smoothly. But you still need to scan for codes. My correct name is DR.RIDLEY
94accordtn
May 7, 2013 01:25 AM
vincentgould
May 20, 2011 12:17 PM
Barry92LX
Jan 25, 2010 07:34 AM
jose310
Mar 15, 2008 12:07 AM
nrmskate
Dec 12, 2007 11:49 AM
