95 LX catalytic converter
Old Dec 30, 2011 | 06:41 PM
gk95's Avatar
Default 95 LX catalytic converter
I replaced the original CAT (155,000 mi) w/a magnaflow replacement. The replacement may not have been the correct part. It fits as far as length & mounting brackets go, but did not have a flange to mount the hanging support on to. After mounting the replacement, as well as adding exhaust hangers to the middle hanger studs & using exhaust straps to attempt to stabilize the forward support bracket the fix makes more noise than the old CAT w/broken heat sheild.
Would it be feasable to hollow out the old CAT & remount it? Also could the rubber exhaust hangers added, when there were none be causing the increased vibration?
Old Dec 30, 2011 | 07:10 PM
Is just the heat shield bad on the old catalytic converter?
Old Dec 30, 2011 | 07:11 PM
gk95's Avatar
Yeah the heat shield was broken away from all but 2 bolts top & bottom. Due to milage & not owning the car for long I decided to replace the cat.
Old Dec 31, 2011 | 07:44 AM
Would replacing/fixing the heat shield be out of the question.
HondaLawgik
Feb 24, 2011 12:14 AM
thunder_x
Jun 3, 2006 06:27 PM
94exsedan35094
May 20, 2006 02:42 AM
St3v3
May 9, 2006 12:53 AM
msmcv73
Mar 27, 2006 05:49 PM
