95 Speedometer not working
Old Jul 20, 2009 | 01:23 PM
CarbonXe's Avatar
Thanks again guys. I'll check into it tonight when I change the rotors/pads.
Old Jul 20, 2009 | 04:39 PM
deserthonda's Avatar
Originally Posted by 00AccordLX5spd
The hardest part will be getting the old cluster out since you have to remove the whole dash.
you do not need to remove the whole dash....it is best to download a manual from the DIY section that will guide you to do the job ......
Old Jul 21, 2009 | 09:58 AM
CarbonXe's Avatar
I have the shop manual for the car, so I'll look into that for removing the cluster. I contacted a few salvage yards about pricing for the cluster, most are $50-100, so I'm going to look around to find a good deal. Hopefully I can get one that has a working speedometer.
Old Jul 21, 2009 | 11:44 AM
00AccordLX5spd's Avatar
Registered User
Dang I sure thought you had to remove the dash in the 94-97 Accords to access the cluster. I guess that's what I get for reading a Haynes manual. I never downloaded the free shop manual because it is for 4cyl accord and I had a 95 V6
Old Jul 21, 2009 | 12:21 PM
CarbonXe's Avatar
Apparently, it could be a fuse. The shop manual says if the speedo, odo, and trip aren't working, check the No.1 10A fuse, then from there check the wiring for the VSS.
Old Jul 21, 2009 | 01:58 PM
Registered User
Definitely check the fuse.
However, if the rest of the cluster works, I would put money on it that the fuse is fine.
hffej54
Mar 14, 2009 06:36 PM
1joker069
Feb 12, 2009 03:16 PM
accordEX99
Nov 3, 2008 02:22 AM
sebastian
Jan 9, 2008 12:10 AM
cclc31
Oct 25, 2005 09:27 PM
