95 Sunroof Stuck
Old Oct 1, 2013 | 08:45 PM
Slomo's Avatar
Default 95 Sunroof Stuck
I just bought a 95 EX and opened the sunroof for the first time it opened right up no odd noises and didnt seem sticky... now when I go to close the roof it stops with about 1/3 of an inch to go. If I look at the roof it appears to be damaged on both corners about tennis ball size dents on each.
I've tried moving the switch back and forth to see if it would go any further,but I can hear the motor working too hard once it gets to the stopping point and dont want to burn it out. I've also tried prying the corners up to see if it were something I could resolve simply by pulling the body up and away from the track, either not strong enough or not the issue. though with the damage on either corner my guess is that is it.
Thanks.
Last edited by Slomo; Oct 1, 2013 at 10:26 PM. Reason: Edit model, Sunroof is stock
Old Oct 1, 2013 | 08:54 PM
camman's Avatar
I have a 97 accord with a sunroof. Is yours Stock? In my car (which 95's are the same) there is a little clip in the roof behind the dome light and you can pry that out and use the tool in your trunk to manually close it.
Old Oct 1, 2013 | 09:40 PM
If it's a DX it shouldn't have a sunroof. Maybe the sunroof is aftermarket??
Old Oct 1, 2013 | 10:27 PM
Slomo's Avatar
The badge is no longer on the vehicle so I assumed, but it is definitely stock... Can you explain where the tool is located in the trunk, or what it looks like?
Old Oct 1, 2013 | 10:41 PM
If the tool is still there, it should be with the tool kit in the spare tire wheel well. See pics.
Attached Thumbnails 95 Sunroof Stuck-manual-closing-moonroof.jpg   95 Sunroof Stuck-tool-kit.jpg
Old Oct 1, 2013 | 11:18 PM
Slomo's Avatar
Thanks for the detailed reply, thats very helpful however I feel like I didnt do a good job explaining the problem as the motor is working just fine it just cant seem to close all the way as if there is some blockage or other damage to the area preventing it from closing just a tad.
jam
Oct 24, 2013 08:11 PM
bcass689
Feb 8, 2008 01:05 AM
HondagalGA
Sep 13, 2006 09:34 PM
xxxcoojaxxx
Jun 30, 2006 12:02 AM
jayem722
Nov 18, 2005 07:06 PM
