96 2.2 bogging and backfiring
Old Aug 15, 2010 | 10:33 PM
Stephenrod's Avatar
Default 96 2.2 bogging and backfiring
my car is a daily driver 2.2 automatic. just started bogging and backfires on me when i accelerate a little give it more gas and it runs fine . i have changed a bad down stream o2 sensor, the plug wires, and ran a scanner over all sensors and cannot come up with a reason why it is bogging. i have also checked the fuel pressure which is also good. please any help would be appreciated. thanks
Old Aug 15, 2010 | 11:03 PM
g22cd5's Avatar
Supper Moderator
humm maybe timing is off? Hade a timing belt job done lately? Or replaced a dizzy??
Old Aug 15, 2010 | 11:12 PM
You didn't mention if the spark plugs, air filter, or the distributor cap and rotor were changed. Change them if they are due. Only use NGK zfr5f-11 spark plugs.
Have you ever cleaned the EGR ports on the intake manifold? Here are several sources on how to clean the EGR ports.
There is a DIY writeup by Hondadude: https://www.hondaaccordforum.com/foru...ad.php?t=28456
Also another site with good info on EGR cleaning: http://www.dhost.info/accordinfo/howto/egr.html
Google T2T013.pdf for the procedure for a 94-97 accord. Its on the last two pages.
Old Aug 15, 2010 | 11:46 PM
g22cd5's Avatar
Supper Moderator
PA got you covered! He knows is stuff!
Old Aug 16, 2010 | 10:44 AM
Stephenrod's Avatar
Hey PA thanks for the info. i just got through cleaning the EGR ports, they weren't completely closed yet, but it is still stumbling and backfiring through the intakeupon slight acceleration while in park. i have tried evrything that i can think of except checking the distibutor. how do i go about doing that? what else could i try?
Old Aug 24, 2010 | 10:25 PM
Stephenrod's Avatar
any out got any ideas why my car is still backfiring through the intake. i change the ECT and it ran good for about 30 minutes and started backing firing through the intake again. something is making it dump to much fuel.
Old Aug 24, 2010 | 10:53 PM
Are there any error codes stored on the ECU?
Old Aug 25, 2010 | 01:10 PM
Stephenrod's Avatar
the oly error code now is A P0135. BUT THAT JUST CAME ON today. so i know that was not the problem.
Old Aug 25, 2010 | 01:12 PM
Stephenrod's Avatar
ok just look at my scanner and it tell me that my CEL is on with code P0135, but not on my dash, but the light will turn on when you turn the ignition on.
Josh Halse
May 17, 2014 09:21 PM
1999HondaAccordEXV6coupe
May 19, 2013 06:59 PM
Dualnames
Nov 1, 2012 07:05 PM
Mdschmidt
Sep 9, 2009 06:07 PM
jamrock
Feb 11, 2009 08:58 PM
