96 accord 4cyl with AC & auto trans
Old Sep 20, 2016 | 06:13 PM
Muskoka's Avatar
Default 96 accord 4cyl with AC & auto trans
My AC is starting to whine as i accelerate. Why?
Old Sep 21, 2016 | 06:57 AM
It may be a bad bearing in the compressor, failing compressor, or perhaps high compressor load due to a restriction in system. Only way to know is to check system pressures and assess. Professional help likely necessary unless you are dedicated DIY'r.
Old Sep 22, 2016 | 03:32 PM
Muskoka's Avatar
If the compressor fails will it damage snything else important?
Old Sep 22, 2016 | 05:16 PM
If compressor seizes, the belt may break which also drives the alternator. Engine will run but if lights are on, not for long.
A seized compressor may cause debris to be scattered throughout AC system requiring replacement of entire AC system to repair.
Old Sep 22, 2016 | 07:04 PM
Two other items it may be is a bad or improperly tensioned belt, or a bad bearing in the compressor pulley.
Ineedabin2
Sep 17, 2015 04:40 PM
drumdoctor
Apr 20, 2014 12:43 PM
spacechimp
Nov 22, 2013 09:21 AM
repark22
Jan 26, 2011 01:02 PM
telemaster1952
Jan 5, 2010 09:57 AM
