96 Accord ABS Light is on
Old Oct 13, 2010 | 08:38 PM
egerms's Avatar
Default 96 Accord ABS Light is on
I have a 96 2.7L Accord with ABS light on. I looked in the Haynes manual and it said it could be a blown fuse or problem with a sensor. I went to autozone and checked the cars computer with a scantool but no error codes came up. How do I figure out what to do without replacing every sensor? Snow will be here soon and I want to fix this by myself. Thanks for your help. If this helps at all the light is not lit until the car begins to move.
Old Oct 14, 2010 | 12:56 AM
deserthonda's Avatar
chk the fluid in the abs reservoir.........94-97 were famous for modulator plugs leakage
Old Oct 14, 2010 | 07:30 AM
AutoZone's scanners probably can't display ABS codes - only engine emmissions codes.
Short the SCS connector as if you're reading error codes the old way (OBD-1). Watch the ABS lamp flash instead of (or in addition to) the CEL.
Long flash & long pause - that's not part of the code yet.
Short flashes = first digit of code
short pause
Short flashes = 2nd digit of code
LONG pause
Short flashes = first digit of next code
etc...
93Accord2.2
Nov 7, 2013 07:10 AM
brayner
Feb 12, 2013 06:59 PM
mickey4live
Jul 6, 2012 08:29 AM
anthonyj89
Sep 24, 2008 10:20 PM
swchan00
Jun 23, 2006 03:17 PM
