96 accord ac issues
Hey guys,
I have a 96 accord ex. Lately the clutch doesn't engage when i turn the air on so i have been knocking it in with a bar on the ennd to engage it and it works about 5 mins then the air gets hot again. Do you think its a fuse issue or is there a way to check the clutch itself to see if it's shot.
Also i pulled a fuse a couple weeks ago and every light in the dash came on and now i cant get them to go off? Do i have to go pay a dealer to reset or is there a different way?
Thanks alot.
Thanks alot.
ok this getting weirder. I just went out and checked all the fuses and relays and when I turned it on it works great and blows ice cold air but it comes on and goes off and comes on and goes off etc. it will not stay constant. Any ideas? Thanks again
You will have to determine if the compressor is losing power on the one wire (red) that goes to it when the clutch disengages.
If there is always 12V, then it could be your clutch gap or the clutch coil. If you lose voltage, then the next step would be to inspect the relay.
frankenstein69
Dec 28, 2014 12:36 AM
Ineedhelp
Jan 22, 2012 07:29 PM
GOT BOOST
Nov 2, 2009 08:32 AM
