96 accord ac issues
Old Aug 17, 2010 | 09:04 AM
neill's Avatar
Default 96 accord ac issues
Hey guys,
I have a 96 accord ex. Lately the clutch doesn't engage when i turn the air on so i have been knocking it in with a bar on the ennd to engage it and it works about 5 mins then the air gets hot again. Do you think its a fuse issue or is there a way to check the clutch itself to see if it's shot.
Also i pulled a fuse a couple weeks ago and every light in the dash came on and now i cant get them to go off? Do i have to go pay a dealer to reset or is there a different way?
Thanks alot.
Old Aug 17, 2010 | 09:33 AM
neill's Avatar
Default update
ok this getting weirder. I just went out and checked all the fuses and relays and when I turned it on it works great and blows ice cold air but it comes on and goes off and comes on and goes off etc. it will not stay constant. Any ideas? Thanks again
Old Aug 17, 2010 | 02:34 PM
Is the clutch plate disengaging when this is happening?
Old Aug 17, 2010 | 02:43 PM
deserthonda's Avatar
chk the clutch gap..........should be .012 to .024 .. if too wide, set it to the smaller setting as close to .012 as you can
Old Aug 17, 2010 | 04:43 PM
kris_loehr's Avatar
Is it full on Freon?
Old Aug 17, 2010 | 07:16 PM
neill's Avatar
yeah the clutch plate disengages then re engages each time.
Old Aug 17, 2010 | 07:41 PM
You will have to determine if the compressor is losing power on the one wire (red) that goes to it when the clutch disengages.
If there is always 12V, then it could be your clutch gap or the clutch coil. If you lose voltage, then the next step would be to inspect the relay.
frankenstein69
Dec 28, 2014 12:36 AM
Ineedhelp
Jan 22, 2012 07:29 PM
thebartender2010
Oct 24, 2011 11:51 PM
GOT BOOST
Nov 2, 2009 08:32 AM
msheehan
Mar 31, 2005 01:18 PM
