Sponsored by:
Sponsored by:
96 Accord cooling problem/plz help!!!
Old 09-07-2010, 12:02 PM
Touge07's Avatar
Default 96 Accord cooling problem/plz help!!!
Hey guys, i just picked up a salvaged 96 accord lx with 125k original miles. Everything seems to be working fine except i just realized that i havent heard the radiator fan come on. Yesterday i was driving slowly around the neighborhood and the temp went up but not all the way to the red, more like in between red and normal. Could this be from the fan not coming on or does it sound like a thermostat or water pump problem. Thanks in advance
Old 09-07-2010, 01:12 PM
Default RE: 96 Accord cooling problem/plz help!!!
I had a similar problem with my 94 Accord. Check the blower motor relay (inside hood, far right, mounted next to headlight) - operates your right fan, left fan is a/c fan.
If this doesn't help by itself, then I'd suggest having your thermostat replaced after.
That's exactly what I did.
Old 09-07-2010, 01:38 PM
Follow the LOWER radiator hose back to the thermostat housing (kinda below the throttlebody). In the T-stat housing is a fan switch with a plastic plug with 2 wires. Unplug that & jumper between the 2 wires with a paperclip or little piece of wire.
Key-ON, that should make both fans run. IF IT DOES, then you've just proven everything is OK in that circuit (motors, wiring, relays, etc) and then you want to replace that fan switch.
If that doesn't make the fans run, post back & we'll have to go from there to figure out what's wrong.
(Don't forget to look for wiring problems at that switch, for example wires pulled apart or broken.)
Old 09-07-2010, 10:45 PM
Touge07's Avatar
thanks for the help guys, when you say jump the switch you mean like with jumping cables to the battery? i think ill try this first before switching anything out
Old 09-07-2010, 10:54 PM
On the green plug that connects to the sensor, connect the two pins together with a piece of wire or a thin paperclip. Then turn the key to the II position.
Old 09-07-2010, 11:09 PM
Touge07's Avatar
Ok great thanks! i was about to jumpstart a switch with giant cables lol. I will hopefully do this tomorrow and ill post how it goes.
Old 09-09-2010, 02:51 PM
Touge07's Avatar
ok guys new update, i did the thin paper clip thing and the fans didnt turn on w the ac on. So where should i go from now,thanks again
Old 09-09-2010, 03:26 PM
Plug back in the temp sensor A. Unplug the connectors to the fans. Start the car and turn on the A/C. Use a volt meter to see if there is 12V across the two pin that plug into each fan.
If you have 12V, then the fan motors are bad. If you don't have 12V, you will have more electrical troubleshooting to do.
Old 09-10-2010, 12:01 AM
Touge07's Avatar
OK ill try to get my hands on a volt meter tomorrow, thanks for helping me out!
Ricardo Barriga
03-10-2013 04:41 PM
d1l
05-13-2010 04:55 AM
pyramidhead
04-17-2009 12:11 AM
cenkaetaya
06-06-2007 12:57 AM
95SiR
04-13-2006 03:27 PM
Quick Reply: 96 Accord cooling problem/plz help!!!
