96 accord ex BRAKES
Old Sep 20, 2009 | 07:24 AM
Saps puddin
Default 96 accord ex BRAKES
I hav a 96 accord ex sedan. The front pads were worn down to the wear clips after 5 months. I replaced rotors ball joints,pads,calipers,wheel bearings, and tie rod ends. Put back together bled and had very spongy pedal. Bled again and master cylinder and still no pedal replaced master cyl. and bled then bled all 4 sides. syill spongy. I am at a loss can anyone help???
Old Sep 21, 2009 | 07:40 AM
Wait - brakes? I didn't see anything about tranny problems...
Since you replaced calipers, the MC would have drained. I've had to bleed tons of fluid before getting all the air out. Keep bleeding.
Old Sep 21, 2009 | 09:54 AM
deserthonda's Avatar
try to bleed it at the brake master see if that helps ,,,,,,,,,have someone pump the brake pedal and you loosen up the tube fitting at the master ....i would use a pipe wrench to possibly avoiding stripping the nut ...
alphaney
Feb 12, 2022 10:14 AM
phantomgrey92
Dec 22, 2015 10:24 PM
ZionsWrath
Jan 25, 2009 11:19 PM
Jcaleno
Apr 3, 2007 10:34 PM
thunder_x
Sep 27, 2006 11:00 PM
