96 accord h22 distributor issues???
Old Jan 26, 2011 | 08:24 PM
accordmatt's Avatar
ive matched up wires and lm still left with extra green. ive tried combinations lm comfortable with and no spark.
Old Jan 30, 2011 | 07:27 PM
accordmatt's Avatar
anyone know the correct wiring for this setup?
Old Feb 1, 2011 | 06:23 PM
accordmatt's Avatar
ok heres a new ? if l did go with the td-60 with it being obd1 would that affect ne thing as far as emissions? would it still connect to my crank sensors in the harness????
Old Feb 1, 2011 | 08:03 PM
Having an H22 swap makes things confusing.
Identify the important components listed below by the vehicle they originated from. Year, Make, Model, like 96 Prelude EX for the H22 engine.
1. Your original accord
2. Distributor
3. Engine
4. Wire harness that is connecting to distributor
5. ECU
6. Fuse box under hood
Once we have that information, we can then figure out the distributor should be wired.
Old Feb 2, 2011 | 08:50 AM
accordmatt's Avatar
96 accord ex f22b1,originally internal coil,using stock accord wire harness,fuse box underhood? yes but not sure why that matters.
93 jdm h22a,p13-a12 ecu,345cc injectors,oil pump swapped with crank sensors,all swapped to obd2,trying to use a td-77u dizzy. l do not have stock coil for dizzy and can not find correct one anywhere.
TD-89u is only internal obd2 dizzy l have found but it had like 8 wires and l dont know how it would be wired up so holding off on ordering. hope this clears things up PLEASE HELP this is all l need to be running
Old Feb 2, 2011 | 12:53 PM
I was tired last night, so the fuse box was not a well thought out question.
Can you try your 96 Accord distributor with the internal coil in the prelude engine?
I am terrible with the abbreviations for the parts. Can you put the year/model of vehicle that the ECU and the distributor came from? What coil are you using with the td-77u?
Old Feb 2, 2011 | 02:21 PM
  #17
accordmatt's Avatar
accord distributor will not bolt up to this motor. and td-77u is a external coil l couldnt find the coil anywhere. so l tried it with my msd blaster 2 coil. l got it to crank many times but didnt run more then 20 secs. getting fuel but wasnt always getting spark so has to be that dizzy. this dizzy is a 97-01 jdm internal
this is my stock harness plug
so how am l gonna have to wire this up?
Old Feb 2, 2011 | 02:23 PM
  #18
accordmatt's Avatar
ecu is the 96 obd2 without immobilizer that dizzy td77u is from a 97+ usdm h22
Old Feb 2, 2011 | 03:10 PM
  #19
Here is what I have figured out:
96 EX Accord 5-pin Connector
YEL - CYP P
BLK/YEL - 12V IG
YEL/GRN - ECU
BLU - TACH
BLK - CYP M
97 EX Prelude 4/2 Pin Connectors
YEL - CYP P
YEL/GRN - ECU
BLK - CYP M
GRN - ICM GROUND (neg coil)
BLK/YEL - 12V IG
BLU - TACH
You have 6 wires on the distributor plug and 5 from the accord wiring harness. Connect the matching pins as described above.
Your missing green wire is negative lead to the coil. You will have to run a wire from that GRN pin of the distributor to the negative lead on the coil.
Old Feb 2, 2011 | 03:55 PM
  #20
accordmatt's Avatar
the dizzy lm getting is a internal one so l dont need to connect up coil. just wires from that connector to my harness. and it wont be here until fri,sat so from what l can see in the picture is
blu
yel/grn
grn/yel
grn
org
white
blk/yel
so l need to figure out how to wire those wires to my stock 5 wires??? and my stock dizzy was internal also
