'96 Accord LX Fan Problems
Old Sep 27, 2006 | 06:10 PM
  #21
sir_nasty's Avatar
Default RE: '96 Accord LX Fan Problems
Ask and ye shall recieve.... check out this link for your FREE MANUAL Download!! It's where I got my 94 manual...
http://hondatech.info/downloads/Auto/Manuals/Accord/
Old Sep 27, 2006 | 06:23 PM
  #22
WhyNotFab's Avatar
What is the Supplement one?
Ab0VE Honda Accord 96 CC7-9 Supplement zip 24.91 MB
I downloaded that, the Wiring Diagrams, and Ab0VE Honda Accord CE1 CE2-96 Service Manual zip 8.78 MB
Thanks alot!!!
Old Sep 27, 2006 | 06:31 PM
  #23
sir_nasty's Avatar
the supplement is usually for additional specifications and more odd-ball model specific stuff that may not have been available at the origonal time of print... At least that's what I understand it to be..
Old Sep 30, 2006 | 05:12 AM
  #24
WhyNotFab's Avatar
I thought everything was fine now.. new fan (works) and both come on with A/C now..but I never got the fan to come on from normal driving, temp. gauge around 3/8. jumped the plug at the Radiator Fan Switch and fan came on.. so I bought a brand new Radiator Fan Switch.. today I drove around alot more even, temp. gauge went closer to 1/2 at times, and I'd stop and check and fan was never on.
When feeling the hoses, the upper radiator hose is pretty hot.. I can hold my hand on it, but pretty hot compared to the lower which is warm but not nearly as hot. Could my switch have not been bad in the first place, but something else (water pump/thermostat instead?) I finally thought I had it all figured out and the switch was an easy fix.. so now, fan $55, Switch $21.. and no luck still..
Old Sep 30, 2006 | 05:18 AM
  #25
deserthonda's Avatar
ORIGINAL: WhyNotFab
if top hose is hot and lower hose is cool or warm,, first thing you do is to replace the thermostat ,, use a Honda t-stat,, make sure to bleed the cooling system after replacement of t-stat
Old Sep 30, 2006 | 05:19 AM
  #26
Slusher's Avatar
Sounds like a t-stat issue, I'm having similar type of thing with mine.
Old Sep 30, 2006 | 05:22 AM
  #27
WhyNotFab's Avatar
So the fan switch replacement might have been pointless? I could return it to use $ towards a t-stat
About how much should I expect to pay for a t-stat?
Old Sep 30, 2006 | 05:29 AM
  #28
get it from Honda cannot be more than 15-20 dollars and it comes with the gasket,...
as for the fan switch i would just leave the new one in..
  #29
Slusher's Avatar
I have just been researching the same thing. First, only a genuine Honda t-stat. Other oem types have drastic differences. Second, you're looking at around $25.
Old Sep 30, 2006 | 05:39 AM
  #30
WhyNotFab's Avatar
Not bad at all.. thanks alot guys!
