96 Accord: Radiator cooling fan fell off!
Old Apr 14, 2011 | 08:25 AM
AustinRules169's Avatar
Default 96 Accord: Radiator cooling fan fell off!
My engine began overheating so I began a process of elimination for the problem, only to find that my radiator cooling fan had fallen off the motor that turns it and is now just resting inside the fan's plastic inner cover. Would fixing this be as simple as reattaching the fan? Or is this a serious problem? Thanks for your help!
Old Apr 14, 2011 | 08:55 AM
crispin's Avatar
I would suggest getting another set from the junk yard or Craigslist.
Should be cheap and easy to find.
As far as reattaching the fan, I wouldn't - next time it comes off it may puncture the radiator costing you more $$ to fix.
Old Apr 14, 2011 | 08:37 PM
Fan probably got "reamed out" by the fan shaft and a loose nut. It happens. A new fan assembly is not too expensive and these motors are not repairable. Check ebay, amazon, rockauto, et al for aftermarket fan assembly.
Uberpippi
Aug 7, 2013 12:42 PM
Novaknowledgenow
May 30, 2013 08:58 PM
darkgreen18290
Apr 16, 2013 11:31 AM
anlam3
Nov 10, 2008 09:11 PM
Tony1M
Mar 27, 2007 12:04 AM
