honda 2002 wont start
Old Apr 14, 2011 | 12:22 PM
outsidethewall's Avatar
Default honda 2002 wont start
My car had cylinder misfire. I changed the spark plugs and was working fine for couple of days. No jerks when driving or in idle. I also changed the filter and added some fuel cleaner. It was working fine until yesterday. This morning however my car wont start. Headlight is working so battery seems to be fine.
Old Apr 14, 2011 | 04:41 PM
Does the starter crank the engine?
(wondering if it's a starter problem vs. a problem with fuel or spark)
Old Apr 14, 2011 | 06:09 PM
it tries to crank for couple of seonds and then stops
Old Apr 14, 2011 | 06:30 PM
Your answer isn't clear. When you hold the key in the start position, does the starter keep spinning the engine?
Old Apr 14, 2011 | 06:49 PM
i just captured a video since I cant explain it. But is there a way to share a video
Old Apr 14, 2011 | 06:53 PM
link to youtube where i posted the video
YouTube - 20070728002540
Old Apr 14, 2011 | 06:54 PM
look at the engine
YouTube - 20070728002707
Old Apr 14, 2011 | 07:07 PM
That is problem with the starter system. It could be the signal, the wiring, the starter, or the battery. It is either the battery or the starter, IMO.
I would disconnect the battery and clean both connections to the starter. You can try jump starting the car. You may want to pull the battery and have it tested.
Old Apr 14, 2011 | 07:41 PM
I went in amd got it text, it said the battery is bad. Thanks for all the help
Old Apr 14, 2011 | 08:43 PM
You guys both beat me to it. The video really sounds like a dead battery.
Luther Stewart
Aug 12, 2020 12:02 PM
jimmy3fingers
Oct 4, 2013 08:02 PM
gasface11
Jul 11, 2012 12:33 PM
Rice4Life
Jun 20, 2011 11:54 PM
MrGmo
Sep 28, 2007 01:40 AM
