honda 2002 wont start
My car had cylinder misfire. I changed the spark plugs and was working fine for couple of days. No jerks when driving or in idle. I also changed the filter and added some fuel cleaner. It was working fine until yesterday. This morning however my car wont start. Headlight is working so battery seems to be fine.
That is problem with the starter system. It could be the signal, the wiring, the starter, or the battery. It is either the battery or the starter, IMO.
I would disconnect the battery and clean both connections to the starter. You can try jump starting the car. You may want to pull the battery and have it tested.
gasface11
Jul 11, 2012 12:33 PM
