96 accord radio
Old Oct 6, 2011 | 11:08 PM
dwnhll's Avatar
Default 96 accord radio
I replaced the origninal radio of a 96 accord with a radio from a 95 accord. Everything works fine, except the light doesn't work. Is there a bulb, a fuse or something that would cause the light to go out?
Old Oct 7, 2011 | 01:16 AM
Hi New Member..Welcome to the HAF..
Was there a reason that this post started out in the ride of the moth thread before I moved it to here?
Old Oct 7, 2011 | 12:55 PM
dwnhll's Avatar
It was done by mistake.
Old Oct 7, 2011 | 12:57 PM
Which light are we talking about?
Old Oct 8, 2011 | 09:10 PM
dwnhll's Avatar
the light that illumimnates the clock and the preset buttons anything else that gets illuminated when the car lights are on.
Old Oct 10, 2011 | 01:17 PM
crispin's Avatar
Originally Posted by harrymac
Yes this is a complex problem however if you are comfortable with some tools here is a step by step answer for you...
Step 1) empty the storage section under the armrest - remove bottom trim plate and remove screws - Pull out cup holder insert and remove 3 screws 2 down in the middle and 1 at an angle pointing towards the dash - remove the armrest and plastic surround as one unit - note you will have to lift the parking brake lever to remove this large piece of plastic.
Step 2) remove 2 screws holding the shifter / dash trim that are now exposed, may also have screw behind ash tray - and remove shifter trim - top part is clipped and the switches are wired so be careful and rotate item out of the way - disconnection wires is not necessary.
this is not an answer to the question the OP asked.
Why did you post this?
He already knows how to remove the radio as he removed the old one to install this new one.
Old Oct 11, 2011 | 02:03 PM
crispin's Avatar
what you need to do is check for power on the ILL circuit.
That is the wire that gets power when you turn the lights on.
It is not the red, blue, yellow, or black wire.
I am not sure what color it is tho.
If there is no power there then I would tie into a switched power wire so that when ever the car is on the radio would be lit up.
djaycardona
Nov 26, 2013 04:07 PM
GMANCRX
Jul 15, 2013 02:50 PM
RecMK5
Feb 13, 2009 06:33 AM
Jeff247
Mar 28, 2007 04:22 PM
gdr_11
Apr 7, 2005 08:58 PM
