96 accord starter installation
Old Dec 21, 2008 | 06:23 PM
ninjaflex
Default 96 accord starter installation
Can someone tell me how to install the starter on a 96 honda accord please.
Old Dec 21, 2008 | 06:27 PM
finch13's Avatar
Default RE: 96 accord starter installation
1. Disconnect the battery
2. Unplug the start solenoid wire (small one)
3. Unbolt the start positive wire (large one)
4. Remove 2 bolts (one is 12mm, the other is 14mm i think)
5. Pull the starter out of the transmission housing.
There may be things in the way though like the upper radiator hose, which can be moved aside.
Old Dec 21, 2008 | 07:02 PM
ninjaflex
I dont need to take off the distributor cap right? It will be able to squeeze out somehow? The start positive wire willl be bolted in or plugged in?
Old Dec 21, 2008 | 09:03 PM
finch13's Avatar
You may need to take the dizzy off, I forgot about that, but hopefully you wont. If you do, it's only 3 12mm bolts (last one is hard to get at with A/C line in the way, but a 6" extension should do)
Start positive is bolted, starter solenoid is a plug. 2 wires on the starter, you can't mix 'em up!
Old Dec 21, 2008 | 10:47 PM
ninjaflex
Thanks for the help! What is a dizzy and its just a bolt on and bolt off? No special way to deal with it correct?
Old Dec 22, 2008 | 09:06 AM
finch13's Avatar
Dizzy = distributor.
It bolts to the head with 3 bolts and you just pull it out. Remember what order the plug wire connect to it or just take the plugs wires out with it.
It has a "key" type shaft on it that only goes into the camshaft a certain way. It looks like ( | ), with the line in the middle offset to one side.
Old Jan 7, 2009 | 08:36 PM
adtanner
I am struggling to replace my starter. I can't get my ratchet to reach the bolts. any tips?
Old Jan 10, 2009 | 09:58 AM
sonnyk88
I just took mine out yesterday. I have to remove both battery and distributor cap. Use some extension with ratchet enough to pass the main starter motor.
dave48103
Aug 15, 2007 11:26 AM
Bilgemaster
Apr 1, 2007 12:42 PM
Fez
Mar 10, 2007 05:01 AM
elmillon77
Nov 18, 2006 05:52 PM
fperezal
Aug 17, 2006 12:21 AM
