96 honda accord LX fuel pump isnt even turning on
Old Jul 14, 2012 | 09:19 PM
hondachic's Avatar
Question 96 honda accord LX fuel pump isnt even turning on
had problems cranking my 96 accord no fuel getting to the fuel line have to break bolts loose on the fuel rail and gas would come out then i would hear the fuel pump and it cranked right up and then it just finally stopped and i didnt hear the fuel pump cutting on when i turned it over i have just changed the fuel pump bought a brand new one and its still not cutting on. have changed the main relay wat else could it be someone pls Help
Old Jul 15, 2012 | 07:47 AM
Is check engine light coming on for 2-3 secs and going off when keyswitch is turned to On?
Check for any codes in ECU (see DIY section for instructions).
Old Jul 15, 2012 | 09:32 AM
hondachic's Avatar
Default reply
the check engine light comes on and stays on never goes off i dunno wat it could be we are stumped! and there is no spark at all.
Old Jul 15, 2012 | 09:34 AM
hondachic's Avatar
could it be a a bad ground?? nothing is coming on at all the car turns over just wont crank
Old Jul 15, 2012 | 09:50 AM
Sounds like time for some testing of the Main relay and the inputs to it.....
I the same thread referenced by TX, there is a link to a manual you can download that will help with the testing.
https://www.hondaaccordforum.com/for...threads-40780/
Old Jul 15, 2012 | 10:18 AM
hondachic's Avatar
even though i just replaced the main relay?? i am not even getting a spark why???? and where do i find the injector resistor at on my vehicle so stump =(
Old Jul 15, 2012 | 11:24 AM
See request to check for codes. This is best path to a solution. Your car is Obd2 so you can go to Autozone or other parts outlet to check codes in most states.
Posting more questions won't resolve your problem.
Old Jul 15, 2012 | 11:40 AM
hondachic's Avatar
thank you will do
Old Jul 15, 2012 | 12:05 PM
Yes, OBD-II codes are good but if you can't get the car to run....the 96's still had the OBD-I connector to get those codes.
I know the relay is new, that is where I'm wondering if the "inputs" to it are missing.
Here is a link that may help : Main Relay Fix, Troubleshooting (Honda, Acura) and how to solder
Last edited by poorman212; Jul 15, 2012 at 01:43 PM. Reason: I can't spell......what is new :)
Old Jul 15, 2012 | 01:26 PM
hondachic's Avatar
ty so much will see what it does hope it fixes the problem =) and if it is missing inputs then wat i need to get another one?? sorry first big problem with this car i cant figure out but hopefully this works ty again =)
