96 honda accord LX fuel pump isnt even turning on
Old Jul 15, 2012 | 02:55 PM
As noted in the following link, if the Check Engine Light stays on after turning the key to ON, it could be a blown fuse (the ECU back-up fuse (7.5A) located in the under hood fuse/relay box), bad sensors, or the main relay.
Troubleshooting ECU Symptoms.
https://www.hondaaccordforum.com/for...d-fuse-box-jpg
Check the fuse first, if that is good, then try to check for trouble codes next.
If the 7.5A ECU back-up fuse is blown, you may be able to find a spare 7.5A fuse in the driver's side under dash fuse box. The attached pic. shows location where there may be spare fuses, look for a 7.5A fuse if you need it.
Attached Thumbnails 96 honda accord LX fuel pump isnt even turning on-driver-under-dash-fuse-box-spare-fuses.jpg
Old Jul 15, 2012 | 03:02 PM
This link shows the blue service check connector to jump with a wire to retrieve any trouble codes.
Blue service check connector
Checking for OBD II trouble codes is better; but, if you don't know anyone with an OBD II reader that can come read your car, then jumping the blue service connector will suffice for now. The OBD II port for your 1996 is located behind the ash tray.
Old Jul 16, 2012 | 10:30 AM
hondachic's Avatar
ty so very much will look at that too hopefully something works so aggravated will do and let yall know thnx redbull-1
Old Jul 16, 2012 | 11:01 AM
No problem. Keep us informed.
Old Jul 16, 2012 | 04:45 PM
hondachic's Avatar
will do =)
Old Jul 16, 2012 | 07:22 PM
hondachic's Avatar
Yay its fixed it was the 7.5 fuse under driver side ty so much redbull 1 and every1 else =)
Old Jul 7, 2013 | 09:54 PM
  #17
Redtop's Avatar
Default Honda accord. 1996
Originally Posted by hondachic
ty so much will see what it does hope it fixes the problem =) and if it is missing inputs then wat i need to get another one?? sorry first big problem with this car i cant figure out but hopefully this works ty again =)
1996 Honda accord I have same problem pretty much turn key on and wait for check engine light to go off then I hear fuel pump and car starts right up, then some times I have to turn key on and off till check engine light goes out. Battery's good bought new cables for it. Had tune up, replaced main relay, fuel pump, fuel filter. No codes come up at all. Now I'm told it might be the fuel injected resister so got off eBay will have it put on,. Anyone have any more ideas thanks
Old Jul 9, 2013 | 05:13 PM
  #18
Did you test the inputs/outputs to the main relay?
Begining to sound like the ecu is giving out - check car-part dot com or e-bay to price a replacement.
Old Jul 10, 2013 | 09:38 AM
  #19
Redtop's Avatar
Default 96 honda
I ordered the injected resister from eBay mechanic told me if that's not my problem, then it had to be ecu . I just don't know what else to throw at it and neither does 4 mechanics. Really hate to get rid of car I've put so much in. Thanks for answering
Old Jul 10, 2013 | 09:39 AM
  #20
Redtop's Avatar
I forgot I have had 2 main relays on
huhdo
Aug 30, 2012 09:06 PM
reut1
Jan 4, 2011 08:08 PM
kissbally78
Jan 18, 2009 07:14 PM
newbie28
Oct 4, 2008 09:08 AM
02BlueAccord
Oct 12, 2007 10:41 AM
