96 Honda Transmission slipping
Old Apr 4, 2013 | 07:54 PM
brian M's Avatar
Default 96 Honda Transmission slipping
I drove to work and transmission was working good, when I was leaving I felt the trans slipping and got worst as I drove. I was able to make home but now when you put in any position its like neutral. No code being pulled from computer.
Old Apr 4, 2013 | 09:41 PM
V-6 or 4-cyl?
How long since the ATF was changed? How dirty was it? Is the ATF level OK now?
Old Apr 5, 2013 | 08:01 AM
brian M's Avatar
Default 96 Honda Tran slipping
I bought honda about a year ago it has about 200K miles on it, trans fuild was about 1/2 quart low, looks like it need to be changed. Is it worth changing fuild or buy a rebuilt trans 2.2 4 cycinder.
what else could I check?
Old Apr 5, 2013 | 08:44 AM
Dirty fluid, smells burnt? I guess I would change it 3x (drive around in between). That's an attempt to avoid replacing the trans.
The torque converter doesn't drain, so when you drain/fill you can only get about 1/3 of the total fluid.
I'm a manual-trans guy, but everyone says the auto trans is pretty good up until 1998. Hope others will chime in, but it seems likely you can go with fluid changes. If it was 1998-2002 then I'd worry about the transmission failing.
daregiri
Dec 31, 2014 02:54 PM
rickdwyer
Dec 1, 2007 11:14 AM
thunder_x
Nov 2, 2007 06:11 PM
milano_6
Sep 19, 2007 10:44 PM
genecrazy
Nov 8, 2006 02:29 PM
