96 Vtec swap?
Old May 4, 2011 | 10:36 PM
carbonfiber89's Avatar
Default 96 Vtec swap?
My engine is starting to get a knock and i was thinking about doing a vtec swap, I as just wondering if anybody else has done it if they could tell me the price/time/difficulty of going through with it. 1996 Accord LX
Old May 5, 2011 | 06:54 AM
Well there are a lot of Honda Vtec engines, so it will vary depending on which one. For example a F22B1 out of a 94-97 Accord EX will swap in and just need a new ECU and a wires run for VTEC. Assuming you did the labor yourself I would expect this swap to cost $3-500. The drawback is it only makes 15hp more than your stock engine
The other popular swap is the H22A/A1/A4 out of the Prelude. Unlike the F22B1 this engine has power making VTEC and makes 200hp which is 70 more than your stock engine. With this engine you would need to modify or replace the driver side engine mount, modify your wiring harness, replace the ECU, and run the wires for VTEC. You would also have to modify your exhaust. Assuming you did the labor yourself I would estimate this swap to cost $800-1500.
If you wanted to pay a shop to do either of these swaps I would estimate the labor to be in the $800-1300 range.
cd51994accord
Jan 30, 2014 12:56 PM
kshellz
Oct 24, 2012 10:51 AM
trukid21
May 4, 2012 02:44 PM
cg31998
Dec 15, 2010 10:29 AM
PTVDesign
Oct 28, 2008 09:20 PM
