97 Accord 5 speed hard shifting and pops out of gear
Old Oct 11, 2011 | 08:12 PM
blackbeauty97's Avatar
Default 97 Accord 5 speed hard shifting and pops out of gear
2 door, auto everything except transmissions a manual. This car was showroom a couple years ago when bought used... now has 150k miles, runs great but always had hard shifting ... but now it's starting to pop out of 2nd and 4th gear .. A year ago we had the transmission fluid checked and greased the shift cable which didn't improve the hard shifting much. Just not sure if it needs a new cable or a new transmission or what! Any advice welcome!
Old Oct 11, 2011 | 09:18 PM
You "checked" the transmission fluid. How about changing the fluid? Use Honda MTF or maybe Pennzoil Synchromesh.
Has it always shifted hard since you bought it? What about bleeding the clutch hydraulic system? (how fresh is that fluid?)
Old Oct 11, 2011 | 09:36 PM
accordmatt's Avatar
hard shift and popping out sounds like bad synhcro's and lock rings
Old Oct 11, 2011 | 09:56 PM
I'll doublecheck to see if the fluids were changed...sounds a lot easier and much less expensive than the synchro and lock rings. So I guess the shift cable being rusty idea doesn't make much sense? Great car, strong engine, no rust..solid, no leaks.. may have to think about investing some $ back into it... Any idea what sychros and rings might mean cost-wise-- sounds like its labor intensive... or maybe a used transmission would be the way to go?
Old Oct 11, 2011 | 10:18 PM
If it turns out to be the transmission, I would get a used transmission. That will be way cheaper than the rebuild. Those manual transmissions rarely fail, so the chances of a faulty used one is low. I would also consider replacing the clutch if you replace the transmission. Check out car-part.com for used transmissions in your area.
Not sure if you are doing this yourself. If you take the car to a shop, the labor cost will be the same as replacing the clutch anyway, because the transmission needs to be removed.
Old Oct 12, 2011 | 08:58 PM
Corroded cables give extra friction in moving the shift lever. That would feel different than a notchy entry into each gear. And it wouldn't explain popping out of gear.
tpstaples
Oct 5, 2021 05:53 AM
letsclique
Jun 18, 2016 04:29 PM
zachxcastle
Jan 23, 2011 10:11 AM
HondaRacer4Vtec
Oct 14, 2007 09:00 AM
MAPULENTO
Feb 12, 2007 08:32 AM
