97 Accord Knocking Sound
Old Apr 29, 2010 | 11:53 AM
Moonraker7's Avatar
Default 97 Accord Knocking Sound
So, for the past few weeks, I've noticed a knocking sound coming from one, or more of my wheels. At first I thought this was the CV joint, which was needing replacement anyway, so I had those done, but the problem continues.
I've also begun to notice that when I hit the breaks hard, I can feel some kind of oscillation, which is consistent with this sound, so I'm assuming this is related to break/rotors. What should I check to confirm what the problem is?
Old Apr 29, 2010 | 10:58 PM
hondadude's Avatar
warped rotor check;
driving at highway speed [60 mph] step on the brakes lightly and feel for a vibration/shimmy in the steering wheel
Old Apr 30, 2010 | 03:42 PM
Moonraker7's Avatar
I feel some vibrations in the steering wheel, though I feel it mostly in the brake pedal itself
Old Apr 30, 2010 | 05:38 PM
deserthonda's Avatar
make sure that everything is tight o the frt end ,, and there are no worn suspension parts
sounds like rotors are warped as well,,
Old Apr 30, 2010 | 06:33 PM
Lightbulb
Might also be getting wheel wobble and wheel bearing noises...
Old May 6, 2010 | 09:31 PM
Moonraker7's Avatar
I had this checked out yesterday and it turns out that my front right rotor is cracked. It looks like it will be about $500 to replace both front rotors and brake pads, does this seem reasonable?
warria98
Apr 4, 2012 03:48 PM
cerbera33101
Mar 15, 2012 09:29 AM
mejim707
Apr 22, 2009 09:25 AM
james_and7
Aug 28, 2008 11:29 AM
mbnjagn
Mar 13, 2008 03:20 AM
