97 accord lx vacuum hoses and P1491
Old Jun 24, 2014 | 05:35 PM
Bange's Avatar
Default 97 accord lx vacuum hoses and P1491
Hi I have a 97 Accord LX with a 2.2L F22B2 engine non vtec with a 5 speed manual transaxle, and I was needing a diagram of where all the vacuum hoses are and what they go to. On my intake manifold there are four places where vacuum hoses should go, I just plugged them up because when left off the idle fluctuates wildly, so I plugged them up and it idles at 750 rpm like it should but when I turn the wheel while not moving or when the AC compressor cycles, the engine bogs down lower than 500 rpm sometimes. The engine also hesitates sometimes on acceleration, I have an aftermarket air filter that is getting crushed by the hood and the battery when the hood is closed, but that's another thing I have to fix and design a way to fit it where the old air box used to be. Also, when coming to a stop, when I press the clutch in it will bog down a lot of the time too. I have a P1491 code that says low EGR lift and was thinking that might have something to do with the engine bogging and slow acceleration. I also need a vacuum diagram of where all the hoses go, I would appreciate it if someone can find me a diagram of that particular car, I've looked online but could not find a clear picture. Also, is there a flowchart to follow for diagnosing P1491, if so it would be a lot of help if I had something like that too. Thanks for any help I may get.
Old Jun 25, 2014 | 05:36 PM
This picture might help for part of it??
Attached Thumbnails 97 accord lx vacuum hoses and P1491-1997-vacuum-hoses.jpg
Old Jun 25, 2014 | 05:43 PM
vet67coupe
Aug 8, 2013 11:18 PM
Racemaster
Jan 15, 2011 06:41 PM
BertMan
Jan 30, 2007 02:15 AM
2001 Accord VTEC
May 19, 2006 07:29 PM
HondaLawgik
Apr 22, 2006 01:05 PM
