97 Accord SE Auto Trans Shift Problems
Old Oct 29, 2009 | 09:01 PM
bobv
Default 97 Accord SE Auto Trans Shift Problems
I have these unusual issues with the automatic transmission:
Approx. 3-5 second delay when shifted from P to D4 for the drivetrain to completely engage, engine warm or cold.
RPM surges (Approx 500 - 700 RPM) while upshifting from 2nd to 3rd and to 4th gears while accelerating in a highway situation (at operating temperature, A/C on or off)
Also, this trans also does a 'sloppy' shift when accelerating after making a turn
(2nd to 3rd, I believe) (Also noticed this on my three 91 Accords as well)
What do you guys think could be going on here???
Thanks............................
97 Accord SE
4 Cyl engine (16 Valve)
4 Spd Auto Trans
Old Oct 31, 2009 | 04:32 AM
jerrym's Avatar
Almost A Senior Member
have you changed the fluid lately or had any service done on the tranny
Old Nov 3, 2009 | 01:12 AM
bobv
Sorry for the delay in the reply.
It acted strange when I bought it last summer so I did do several fluid changes in the transmission with Castrol Import ATF and Lucas Transmission Additive.
No help.
Should I try using the Honda ATF?
Old Dec 27, 2009 | 08:25 PM
CAaccord95lxwag's Avatar
Default Same here
Mine also does the 3 or 4 second full P to D4 shift. My transmission only has 71K on it. I don't have any other issues though, it shifts through the gears fine, a little hard from what I am used to(2000 Tacoma 4x4 AT 4spd), but I read this is just the way they shift normally. I am going to change my fluid this week, with Honda fluid.
Old Dec 28, 2009 | 03:08 PM
jerrym's Avatar
Cool
I only use Honda ATF in my 97 Accord, which has 162,000 miles on it. When the engine is cold I do notice a slight slip from going from 1st to 2nd gear, but it goes away when the engine warms up.
A tranny mechanic mentioned that the seals wear and when the engine/tranny is cold the seals are brittle and leak by causing the slip.
How many miles are on your car?
Tenorman51
Jan 3, 2014 06:11 PM
accordfan
Mar 16, 2013 11:05 AM
hondamanic
Feb 1, 2011 12:04 PM
Steelroy
Dec 21, 2007 07:59 PM
Mohlmann
Jun 22, 2006 12:33 PM
