97 accord v6 oil filter housing
Old Sep 29, 2015 | 12:55 PM
DoG Dragonslit's Avatar
Default 97 accord v6 oil filter housing
Ok so my new 97 accord v6 2.7 auto 4 door is nice. But it's spewing oil from the oil pump housing where it attaches to the engine. Anything I need to know when replacing this? I hear it's a figure 8 gasket.thanks for any help.
Old Sep 29, 2015 | 01:07 PM
Are you sure it's not leaking from the oil filter/VTEC solenoid housing attachment to the block? There is a oring seal between this fitting and oil pump housing.
I looked at a 98 Accord shop manual which is likely similar to yours. Oil pump housing removal requires removal of timing belt assy, Vtec/Oil Filter housing, and oil pan.
A Honda shop manual is recommended.
Old Sep 29, 2015 | 01:18 PM
IL get a manual and pray to God I don't have to do that.
Old Sep 29, 2015 | 07:19 PM
The leak is usually due to the o-ring between the oil filter housing and oil pump, not usually the oil seal between the oil pump and engine block. Therefore, if it is due to the oil ring related to the oil filter housing, then there is no need to remove timing belt, etc.
See my post in this other thread:
https://www.hondaaccordforum.com/for...et-help-56880/
Old Sep 29, 2015 | 07:27 PM
Ok so I got the housing away from the engine and the figure 8 oring is hard as a rock. So it just needs to come out
Old Sep 30, 2015 | 04:43 PM
Got it replaced now I can't get the car started. Won't even turn over. Any ideas
Old Sep 30, 2015 | 06:09 PM
Check for disconnected or damaged grounds.
Do you have power to the dash? If yes, check for start signal on small blk/wht wire to the starter.
Old Sep 30, 2015 | 06:18 PM
It was a dead battery. I feel stupid. Everything works it idles low and if revved at all it dies when it comes back down
11_22_1992
Jun 19, 2015 12:20 PM
Bruce Arnold
Nov 25, 2013 09:54 AM
bjr001
Mar 5, 2010 07:31 PM
jose310
Mar 31, 2008 03:12 PM
nygamble
Jun 11, 2006 07:13 PM
