97 Accord won't rev past 5500 rpm
Old Feb 28, 2013 | 08:55 AM
  #111
Roader's Avatar
96 - 97 F22B1s didn't have VTEC oil pressure switches, which is why I was asking about an engine swap.
Take a pic of the the switch that has no connector on it and post the pic here.
Old Feb 28, 2013 | 12:04 PM
  #112
Sorry; I didn't realize those years didn't have the oil pressure switch.
Maybe not an engine swap, but maybe just a junkard VTEC spool valve from a different year??
Old Feb 28, 2013 | 12:44 PM
  #113
Port In's Avatar
im kinda having the same problem i dont really kno much about cars thats why im here trying to figure out wats wrong i have a 95 accord 4cyl vtech and it seems to redline at 5000 and my friend told me there was smoke coming out at the high rpms (he was driving behind me) any input would be apprieciated
Old Feb 28, 2013 | 05:08 PM
  #114
Roader's Avatar
Originally Posted by JimBlake
Maybe not an engine swap, but maybe just a junkyard VTEC spool valve from a different year??
Could be. You never know on a 16-year-old car what you'll find. There's also the possibility that a previous owner converted it to OBD1 - including the ECU - and that ECU is looking for a VTEC oil pressure switch.
OP: the middle numbers on your ECU should be P0H. That's a '96 - '97 VTEC ECU that doesn't have an input for the VTEC oil pressure switch.
Old Mar 16, 2013 | 04:11 PM
  #115
RP94ex's Avatar
Not wanting to hijack this thread but but i had the same problem on my car twice in a 2 year interval
and it was the ecu both times. try with a other ecu and see if that works.
Old Mar 16, 2013 | 09:57 PM
  #116
Trying to help isn't hijacking - no worries.
Old Mar 8, 2024 | 10:34 AM
  #117
Cordruler's Avatar
Originally Posted by Cody_754
1997 Honda Accord SE with a JDM F23 VTEC swap. Running the P0H-L51 ecu. Engine seems to lose all power at about 4500 then acts like there's a rev limiter at 5500. No CELs! VTEC is not engaging I don't think. Any thoughts?
I have a 96 accord coupe LX. It came with f22b2 original then the idiot owner before me did a full motor swap to a f22b1 but didn’t change harness and ecu. So vtec never activated and literally never went past 4k RPM. One simple fix. Put a small piece of round metal that will allow oil to flow thru. (Unbolt the top of the vtec solenoid, you’ll see a cylinder piece of metal. You’ll want to put a tiny round piece of metal on top just big enough to slide down the cylinder wall with the cylinder and it doesn’t take much probably something that’s 2cm thick) She should be redlining above 6000-6400k RPM but it definitely rips up to 5,700-5,8000k. Not sure If that’s the ecu fault or if it’s the f22b1 intake manifold not having as much air flow, causing it to lose breath. But that’s the cheapest fix I know of.
Mbowden97cd5
Jan 26, 2018 09:41 PM
2009antz
Aug 23, 2012 10:25 PM
F23Chris
Feb 8, 2010 10:12 AM
grkacl
Nov 30, 2009 02:10 PM
dinzer
Oct 18, 2005 10:27 AM
