97 honda accord automatic transmission shift problems
Old Jul 5, 2011 | 09:17 PM
kevinkeith1973's Avatar
Default 97 honda accord automatic transmission shift problems
My 97 Honda accord of lx automatic transmission. Having trouble shifting into 4th gear when getting up passed 60 MPH. At70 its rpm is at 3000rpm.when could the problem be. Checked shift silnoid.good. no code. Its has 110.000 miles on it. Both shift and thottle cables have slack. If I tighten the slack .could that make a diffenerce. Help please. This is work car. All. I do is interstate driving
Old Jul 5, 2011 | 09:30 PM
Tek310's Avatar
i have the same problem, ive been too busy to adjust the shift cable.
which solenoid did you check?
one on top of transmission or the one facing the front of the vehicle?
Old Jul 7, 2011 | 07:14 PM
If nothing else, can't promise it will solve the issue, the throttle control cable should be properly adjusted......actually damage can be done if not adjusted properly. Start there and then report back.
drfence
Sep 26, 2012 11:17 AM
swingkid50
May 20, 2012 09:29 PM
dal_loma
Jul 2, 2009 06:33 AM
Corysez
Nov 25, 2007 08:15 AM
