97 Inner tie rod squeek
Old Oct 31, 2011 | 05:47 AM
Check ericthecarguy videos for one on replacing PS rack (i think) that covers special wrench for inner tie rod release/makeup.
regards
Old Oct 31, 2011 | 07:05 AM
jbeebe's Avatar
regards
i've seen those special pipe tools for it, but ericthecarguy just took a pipe wrench on the "ball" and it seemed to work, good to know if i end up replacing the whole inner tie rod. thanks!
Old Nov 7, 2011 | 04:54 PM
jbeebe's Avatar
update. took off the passenger side boot and saw that the inner tr was pretty flimsy, so i replaced it and a new boot.
the squeek is still there! it's whenever there is any tension on the steering system at all. it's coming from the end of the rack and pinion (or at least it sounds like it from underneath). like i said, it's not a metal on metal squeek, just a weird noise. think it could just need a fluid change? the steering itself is perfect, no sticky-ness.
Old Nov 7, 2011 | 06:47 PM
Check the rack tie-downs and restraint. A loose rack might cause the squeaking.
96FiveSpeed
Feb 12, 2010 09:54 PM
trukid21
Jul 22, 2008 08:19 PM
pacallen
Mar 18, 2008 07:54 PM
trukid21
Dec 5, 2007 11:12 AM
Tony1M
Jul 3, 2006 08:12 PM
