97 - Intermediate bearing on driver's side axle
Old Aug 21, 2010 | 09:21 PM
FrankvH's Avatar
Default 97 - Intermediate bearing on driver's side axle
I have a 97 Accord that has noise and vibration coming from the left side at the front. After a drive, I feel the left wheel and the intermediate bearing between the CV axle and the little stub axle to the transmission. Both seem quite hot, though the intermediate shaft bearing seems REALLY hot. "Can't touch it long". Anyone experienced this? Do you buy a whole new shaft and axle, or just change bearings in the intermediate thing. OR, do you get a whole new housing and bearing for the intermediate bearing?
I want to do the most efficient, smartest thing. Not necessarily the cheapest.
How likely is it that the real problem is the wheel bearing, and intermediate one always is hot? I think I might change both while I'm removing all that stuff.
Old Aug 22, 2010 | 09:27 AM
FrankvH's Avatar
Default Yes, there is a stub shaft, half shaft, etc
Between the tranny and the outer CV/axle assembly there is a short shaft that ends in a bearing bolted to the tranny, that the CV shaft splines into. It's what they call a stub shaft or half shaft. Otherwise, the CV axle on that side would be really long.
Old Aug 22, 2010 | 01:52 PM
Looks like the bearings are available (theoretically). They're numbered on the picture, but Majestic doesn't list them on-line. Maybe have to special-order them from a dealer???
Old Aug 22, 2010 | 04:05 PM
kris_loehr's Avatar
I belive the OP has a V6 which is listed. I have never seen a V6 97.
Old Aug 22, 2010 | 05:24 PM
piggylover1985's Avatar
I worked on a couple pre 98 Accord with a 2.7 V6, looks almost like the one from the earlier Acura Legend.
Samzebian
Apr 30, 2011 01:03 PM
corlude
Oct 31, 2009 12:38 AM
LCS
Feb 11, 2009 01:27 PM
toddyfresh
May 16, 2008 09:55 PM
95 exR
May 24, 2007 08:05 PM
