97LX 2.2L cracked camshaft
Old Oct 2, 2008 | 07:50 PM
fargocraig
Default 97LX 2.2L cracked camshaft
The cam gear was found to be loose on the shaft although the bolt holding it on was tight. Cam key is deformed and a crack radiates through the bolt hole.2 questions: has anyone seen this before and can shed light on the cause? and, will a replacement cam last or do I need to replace both the head and the cam? Well maintained, timing belt is a year old. Have a great day! signed, "there goes all my fun money."
Old Oct 2, 2008 | 08:23 PM
Default RE: 97LX 2.2L cracked camshaft
If you mean the keyway where the distributor key enters the slot on the camshaft, it might be possible to damage the keyway w/ improper installation of the distributon. I did this once, but damaged the distributor rather than the camshaft. Only bolt-hole in the camshaft holds the timing sprocket in place on the camshaft.
Also the Lx has have the camshaft assy removed to access the orings that isolate the spark plug tubes. If someone did this job improperly, they might have damaged the camshaft,
... or maybe your car was that 1/100000 w/ a crack in the parent forging that was undetected by NDE. I'm sure it happens.
Old Jul 21, 2011 | 11:08 AM
barhillsman's Avatar
Default cracked camshaft too
I am actually dealing with a head gasket leak / repairs using help from this forum, but I have the same engine only a 96 version, and after taking the cam out I noticed mine was also deformed and cracked, so I guess thats 2/1,000,000
Old Jul 21, 2011 | 11:35 AM
g22cd5's Avatar
Supper Moderator
Did you remove the camshaft caps in the right order while at TDC? If not that’s why you have cracked your camshaft.
Old Jul 21, 2011 | 12:08 PM
draser's Avatar
Hard to say why it cracked. Number the brearing caps and put an arrow on top to keep same orientation, then remove. Your problem would be a bent camshaft, and looking at the bearing wear and camshaft journals you should get a good idea if you see uneven wear. If you can rotate the gear by hand and you don't see bearing wear you're ok. Just replace and install caps back.
Old Jul 21, 2011 | 02:22 PM
g22cd5's Avatar
Supper Moderator
In most cases when you remove sohc cam caps out of order you snap the cam at the least you crack and or "warp" the cam. Camshaft should not warp nor crack unless something was put 2geather wrong and the engine ran that way. The cam has to be set even or it will cause failure same thing with removal.
Old Jul 21, 2011 | 07:27 PM
If I understood your post, the camshaft sproket was loose, woodruff key was damaged, and a crack radiates from the hole which the camshaft retainer bolt threads into.
This suggests something stopped the camshaft which is driven by the timing belt, causing the woodruff key to attempt to shear. Key might jam and wedge into space between sprocket and camshaft causing the crack.
This might also cause misalgnment of crankshaft and camshaft timing and potentially damage valves.
It is unclear what might cause camshaft to be stopped. Perhaps a binding valve (hitting piston). This might cause enough resistance to shear the camshaft woodruff key. If someone were turning the crankshaft manually, this might be more likely.
Chaz57
Jun 14, 2007 07:07 PM
maro
May 14, 2007 06:17 PM
dodins
Mar 18, 2007 08:10 PM
YeuEmMaiMai
May 29, 2006 05:09 PM
kjinpb
Aug 19, 2005 10:42 PM
