98 accord, 2 door, 5 speed instument cluster
Old Apr 25, 2012 | 10:20 AM
anotherreject's Avatar
Default 98 accord, 2 door, 5 speed instument cluster
i have a 98 accord, 2 door, 5 speed 4 cyl. the instument cluster needs replaced (the temputure gauge is bad). im having trouble finding a direct match replacement. i need to find out if the instrument cluster for an automatic will fit. the automatic has the light up gear selector inbetween the temputure and fuel guage, the space on the 5 speed cluster is blank.
Old Apr 26, 2012 | 06:58 AM
anybody?
Old Apr 26, 2012 | 10:51 AM
We are having some problems with the site.
You want to be sure that the signal for the temperature gauge is working properly. The signal comes from the temperature sending unit. It is on the engine block and has one wire in the electrical connector.
That sending unit should be on the passenger's side of the engine sort of below the distributor. What happens to the gauge in the car when you unplug that sensor? Make sure that the electrical connector does not touch any metal.
98accordman
Mar 15, 2020 01:34 PM
socaldave34
Oct 18, 2012 06:09 PM
irhunter
Mar 23, 2011 04:49 PM
gahonda
Jun 25, 2010 09:16 AM
marbro
May 20, 2006 10:13 PM
