98 accord D4 Light out and shifting problems
Old Nov 13, 2012 | 01:56 PM
wilfrejavier27's Avatar
Default 98 accord D4 Light out and shifting problems
In my cluster D4 lights out and the cars doesn't shift smooth, all the others light up (P, R, N, D3, D2, D1). Sometimes it holds second gear and more longer then switch to the 3rd gear. It doesn't have a smooth gear switching. I really appreciate all your help. Thank You!!
Old Nov 13, 2012 | 08:18 PM
Well you may not like my answer. First, many parts stores will scan for codes for free. Be sure to get the actual code from them (p0740 for example) and not their description of the issue. Cleaning a solenoid or two might solve the problem
Next, the auto trans in the 98-02 do not have a good rep.....they can last a long time with the issues you describe. If you ever have to get the trans rebuilt, be sure the proper upgrades are installed to help prevent the issue from coming back.
Old Nov 13, 2012 | 08:54 PM
How's your transmission fluid? Have you changed it? Was it / Is it dirty? Did you use Honda fluid? Did you have it power-flushed or just drain & fill?
Old Nov 13, 2012 | 11:25 PM
My transmission was rebuild a year ago. After that I found a a pressure sensor broke and I replace it but still doing the same thing.
Old Nov 13, 2012 | 11:28 PM
OK I will do the scanner to see what codes does it have. Thank you for your help.
Jessicac1990
Oct 17, 2012 06:15 AM
andydena27
May 18, 2012 05:21 PM
blackbeauty97
Oct 12, 2011 08:58 PM
Tyltong123
Apr 6, 2008 01:06 AM
