98 Accord Electrical problem
Old Feb 27, 2014 | 06:19 PM
ButchT53's Avatar
Default 98 Accord Electrical problem
Bought this 98 Accord LX 4door, 4cylinder, automatic, several months ago for my daughter.
The horn did not work, everything else worked as it should. After driving it a few days the cruise control malfunctioned. It began accelerating even when touching the brakes or pressing cancel button on the steering wheel. Had to brake untill stopped then shut off the engine. I pulled the fuse for the cruise control and the transmission would try to start in high gear, replaced the fuse then had a long list of electrical problems. Dash lights, radio, clock, interior lights, vanity visor lights, running lights/parking lights do not work. The heater blower does not start immedeatly but after driving a short distance it works normally. I have replaced the drivers multiplexer with a used one and the light switch on the steering column, new. I do not have a repair manual or wiring diagram for the car. Any help or direction will be appreciated.
Old Feb 27, 2014 | 06:44 PM
Roader's Avatar
Old Feb 27, 2014 | 07:11 PM
Check the other fuses as well.
Drivers side #8 7.5amp and #9 7.5 amp.
Pass sdie, #13 7.5 and #9 20 amp.
Does the power/accessory socket work?
Old Feb 28, 2014 | 12:24 PM
ButchT53's Avatar
All fuses are good, drivers side #8, #9 has voltage on the fuse socket, Also D4 on the shift selector is flashing. Passenger side fuses are good with no voltage on fuse socket #13 or#9. The power accessory socket has no voltage.
Old Mar 1, 2014 | 09:36 AM
Just so I'm clear. On the pass side fuse box you have no power at either pin of the #13 or #9 fuse socket?
If this is true, check the large amp fuse in the underhood fuse box. #54 40amp fuse.
Old Mar 1, 2014 | 12:53 PM
ButchT53's Avatar
Thanks, I will check #54 fuse under the hood tonight. A side note, the power window fuses in the passenger side fuse panel have power.
Old Mar 2, 2014 | 05:49 AM
For the power window fuses, not sure of the fuse numbers you are testing, many of those a "fed" by #51 40amp underhood fuse.
Attached Thumbnails 98 Accord Electrical problem-6th-gen-power-window-dia.jpg
Old Mar 2, 2014 | 10:09 AM
ButchT53's Avatar
Thank you poorman212, found the problem, and it was self inflicted. I had pulled 40 amp fuse #54 earlier and put it back in the wrong slot. That is one of the dumbest things I've done lately. However, my eyes are not as good as they once were. Again, many thanks.
Old Mar 3, 2014 | 06:03 PM
Thanks for the follow up.
Are all things "back to normal" now?
Trust me, I've done some pretty good ones myself.
TRIGGA
Oct 19, 2007 01:57 PM
roadman1977
Dec 30, 2006 04:37 PM
SnowDog1026
Dec 26, 2006 01:16 PM
eddyfurukawa
Feb 13, 2006 03:15 PM
qbtarget
Feb 13, 2006 01:56 PM
